Allways device out-of-sync
mmisonne
Level 2
Level 2
Hello
I allways have out-of-sync device.
I Have LMS3.2  with RME 4.3.1
Although, I configured "exclude command" with "ntp-clock priod .certificate. and so on." for the dev category "switch and hub".
But  when I click "out of sync" it allways shows me the device ( SW 2950..SW3560 .) with difference  like ntp-clock.
This happens also after a new config ftech.
Can you help me .
Rgards
Michel Misonne
Joe Clarke
Post a screenshot showing the diffs as RME sees them.
Hello Jo
Here is my screenshot.
I noticed also that the device which are allways out-of-sync are 3560V2.
If I checked the device pakage , I have the package "Cat3560" ver 7.1
Rgds
Michel
Hello again
Finaly,I made a Device Update  for all RME device, and it works fine now.
Regrads
Michel
