Alternate way to log into switch on network
Sanremo
Hi, I would appreciate if someone could help me with a network issue.    I have a remote location with a switch I can not log into.    I can remote into PC -> CBS250.
However, I have a CBS350 that is connected to the CBS250 that I can not log into.   Bonjour LLDP show the CBS350 as Neighbor with IP 192.168.2.2 but that IP does not work.  The business dashboard shows the CBS350 as online.
I would greatly appreciate if there is any alternative way to log into the CBS350.
5 Replies 5
Joseph W. Doherty
Have you tried connecting to the CBS350 from the CBS250?
Okay, so the CBS350 shows an IP of 192.168.2.2, how's the CBS250 connected interface configured, and what SVIs are on the CBS250?
Sanremo
Hi, I use VLAN 1 as default on the CBS250, but I see the neighbor info shows VLAN 0 for the CBS350.  On the CBS250 I can only add VLAN «2» and higher, not «0».
Hmm, VLAN 0, eh?  Well, if frames are VLAN tagged, but VLAN ID is zero, the tag is just for CoS.
Possibly, VLAN 0 might be indicative of a "routed port" as I believe a CBS350 is a L3 switch.
Hi, thanks for reply.    I have tried changing VLan and other settings on the CBS250 to get  access to the CBS350 without success.    Looks like I have to wait until I am back on site.
Are you even sure the CBS350 is even configured to allow any access via its network ports?  If not, even though the switch is "visible" via LLDP, you won't be able to remote access it "on-net".
On Enterprise small routers, they often allowed one router's console port to be connected to another's AUX port and you could do reverse telnet. I don't know if that's a possibility with those two CBS switches.
