AP 1200, VLANs, Procurve 4000
brainfry22
Hello all,
This is my first try at using Cisco anything. I am having trouble setting up vlans on a 1200 ap using procurve 4000 switches. I need two vlans , one for data, and one for ip phones (which will be broadcast ssid). The problem comes when I make the vlans, I cannot ping anything after I connect to the ap. I tried leaving the primary ssid open with no vlan, and the second ssid mapping to the default vlan. When I do this I can ping the RADIUS server with the VLANed ssid, but not connecting with the primary ssid. I know there are a thousand things that can be wrong with this setup, but I need a point in the right direction.
Thanks All
umedryk
Level 5
Level 5
You can check www.cisco.com/techsupport/-----> products --------> Wireless --------> select the products and then click on Troubleshooting section. You will find general troubleshooting documents which might help you.
