application registration
miheg
Level 9
Level 9
After setting up single sign-on and DCR master-slave I've tried to do application registration between 2 servers both running Common Services 3.2.
The idea is to have all application on the same page. My customer would like that, so I try.
Where I enter the other servers address it goes out and finds the applications on the other server, but when I select an application and click "Finish" I get an error:
Problem with File /WEB-INF/screens/cmic/Application_Registration/Imported_Application_Summary.jsp!!!Getter for property importSummary threw exception: java.util.NoSuchElementException
Are the other ways to accomplish this registration?
Cheers,
Michel
akemp
Level 9
Level 9
So are you registering from template or from the server ?
Do you have the current PKI certs installed on all the boxes involved ?
Do you have the common account set up ?
Yes, I have. Otherwise the single sign-on would not work either.
And I doubt I would receive a list with the applications on the other server if there was some problem with the certification or the account.
Cheers,
Michel
I found the solution to my problem via a tac case.
I assumed that for correct functioning of the application and for being displayed on the ciscoworks main page they need to be registered with the server then are running on.
That is not the case. I had a fully working QPM server, but the applications were not registered on the home page of the server.
This is however required for a remote ciscoworks server to get access to the portlets.
Cheers,
Michel
