Archive config command not available on 2621 12.3.(26) HELP!
doug.chubb
I am trying to configure the router to send configs to my tftp server
I would normally use archive config but the command is not available.
I am running a 2621 with this image
c2600-i-mz.123-26.bin (IP image).
Anyone have any ideas?
doug.chubb
I amend my question above. I know I can send the config with the copy command. I want to use the archive command to be able to compare configs and have an auto write when the wr mem command is issued.
Doug
The config archive feature was not added until 12.3(7)T. You will need to upgrade this device. You should probably consider moving to 12.4 mainline instead of 12.3T.
