ARP protocol drops the frame
oscar03
I have configured 3 routers with OSPF and they are also been use as DHCP servers. The pc's connected are able to ping all the routers, but they cannot ping from one side to another. Always seems to have the same problem, "ARP protocol drops the frame".
Any solution?
Here's my program
https://www.mediafire.com/file/r72cuqe1xkl2urt/Cisco_Oscar.pkt/file
@oscar03
You are using the same network in two different place in the topology. It will not work this way.
Just use different network address.
It is possible to use the same address in different places and use NAT to mascarate it, but, you should use static nat and not overload as you are doing.
5 Replies 5
Mark Elsen
  - FYI : Community group for Packet Tracer project questions
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Joseph W. Doherty
ARP shouldn't jump across a L3 hop.  So, if that's what you're are describing, it's expected behavior.
As to being unable to ping from one side to another, there's multiple possible causes.  At the moment, respondng from my phone, cannot, at the moment, examine your PT attachment.
Most common causes are insufficient routing information and hosts without a default gateway.
@oscar03
Ah, well that's falls into the "multiple possible causes" category, although perhaps not as common as other errors.
IP subnets, generally, expect to be use the same L2 broadcast domain.  This is why ARP fails.
Realy tnx man, I have been hours trying to solve this problem!!!
