11-22-2012 08:04 AM
Any one see the pronl;em where LMS 4.2.2 cannot backup an ASA 5525-X (UKHSL-N01-AFW02)..
The Inventory collection is fine, to a point.
I have applied all updates LSM etc
Ian
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-10],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericConfigOperator,getOperator,72,Got the operator for in GetOperator
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-10],com.cisco.nm.rmeng.dcma.configmanager.ConfigOperatorThread,run,61,Got the Cli Operator Ifcom.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericConfigOperator@11dc32c
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-10],com.cisco.nm.rmeng.dcma.configmanager.ConfigOperatorThread,run,64,Adding to Operator List
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-10],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,triggerConfigFetch,56,#### Start of Sweep Thu Nov 22 15:23:10 GMT 2012 ####
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4175,ConfigFetchArgs value for this device is com.cisco.nm.rmeng.dcma.configmanager.ConfigFetchArgs@12b6836
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4179,ConfigFetchArgs value Req Id for this device is 1353597789754
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4181,ConfigFetchArgs value Device Name for this device is UKHSL-N01-AFW02
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4183,ConfigFetchArgs value Device Id for this device is 161
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4185,ConfigFetchArgs value fileTypesToFetch for this device is 3
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4193,User Context Value = com.cisco.nm.rmeng.dcma.configmanager.SecurityContext@c6e417
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4197,UserContext User Name value for this device is
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4199,UserContext App Name value for this device is Archive Mgmt
[ Thu Nov 22 15:23:10 GMT 2012 ],INFO ,[Thread-91],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,performCollection,4201,UserContext App Version value for this device is 5.2.2
12-12-2012 02:55 AM
This is still an issue for the back up of a ASA5525-X
[ Wed Dec 12 10:48:27 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericConfigOperator,fetchConfig,88,I am here
[ Wed Dec 12 10:48:29 GMT 2012 ],ERROR,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchiveForDevice,1899,PRIMARY STARTUP Config fetch Failed for UKHSL-N01-AFW02
[ Wed Dec 12 10:48:29 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,129,resource is not null....
[ Wed Dec 12 10:48:29 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.DBInterface,updateStatusTable,643,Calling UDMDeviceAccessManager.updateCollectorStatusTOUDM
[ Wed Dec 12 10:48:29 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,addToDeviceQ,37,Adding the Device for UDM Status Update After Config Collection 161
[ Wed Dec 12 10:48:29 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericConfigOperator,fetchConfig,88,I am here
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,run,44,Going to update the UDM devices 1
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1864,+++ getDCRIdMapLite +++
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1867,CSV converted values:161
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1869,Query SELECT DCR_ID,NETWORKELEMENTID FROM DM_Dev_State WHERE NETWORKELEMENTID IN (161)
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,88,Getting DCR ID for the deviceID161
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,97,Got the DCR ID for the deviceID161
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,120,Going to Call the UDM
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,122,Going to delete the MemoryCache of Devices
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.cache.load.MemoryCache,deleteMemeoryData,296,Going to delete the device from Memory Cache DCR device is 161
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.cache.load.MemoryCache,deleteMemeoryData,296,Going to delete the device from Memory Cache UDM device is 161
[ Wed Dec 12 10:48:30 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,125,After Deleteing the Memory Cache of Devices
[ Wed Dec 12 10:48:31 GMT 2012 ],ERROR,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchiveForDevice,1899,PRIMARY RUNNING Config fetch Failed for UKHSL-N01-AFW02
[ Wed Dec 12 10:48:31 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,129,resource is not null....
[ Wed Dec 12 10:48:31 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.DBInterface,updateStatusTable,643,Calling UDMDeviceAccessManager.updateCollectorStatusTOUDM
[ Wed Dec 12 10:48:31 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,addToDeviceQ,37,Adding the Device for UDM Status Update After Config Collection 161
[ Wed Dec 12 10:48:32 GMT 2012 ],INFO ,[Thread-63],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,writePerDeviceResultFile,3201,Serializing the Device Result = D:/CISCO_~1/files\/rme/jobs\ArchiveMgmt\1686/161.device
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,run,44,Going to update the UDM devices 1
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1864,+++ getDCRIdMapLite +++
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1867,CSV converted values:161
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDCRIdMapLite,1869,Query SELECT DCR_ID,NETWORKELEMENTID FROM DM_Dev_State WHERE NETWORKELEMENTID IN (161)
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,88,Getting DCR ID for the deviceID161
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,97,Got the DCR ID for the deviceID161
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,120,Going to Call the UDM
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.dcma.configmanager.UDMDeviceStatusUpdater,updateUDMDeviceStatus,122,Going to delete the MemoryCache of Devices
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.cache.load.MemoryCache,deleteMemeoryData,296,Going to delete the device from Memory Cache DCR device is 161
[ Wed Dec 12 10:48:36 GMT 2012 ],INFO ,[Thread-27],com.cisco.nm.rmeng.util.cache.load.MemoryCache,deleteMemeoryData,296,Going to delete the device from Memory Cache UDM device is 161
12-12-2012 12:28 PM
12-13-2012 02:02 AM
Inventory is no problem that works for me also.
Its the archive of the CFG that fails.
12-13-2012 02:38 PM
Hi Ian, sorry about that. I dug deeper on mine and am seeing the same error as you.
I tweaked the transport and timeout stting etc. and had no luck. I checked my ASA while trying an unsuccessful archive sync and noticed that I was authenticating but then the ssh sesion was terminating with an error message 315001: reason: "Internal error" (0x00).
I doublechecked my ssh setup on the ASA and it's all correct. I even ssh'd in from the LMS console successfully to verify that the ssh key exchged OK with LMS. that all worked. So I turned on debug ssh on the ASA. I see the ssh key excahnge work OK, my authentication is granted OK and then the session drops unexpectedly.
It certainly looks like a bug to me. My other devices, including a 5510 running 8.4, are working fine.
5515X debug ssh excerpt:
SSH2 1: authentication successful for mrhoads
SSH2 1: channel open request
SSH2 1: pty-req request
SSH2 1: requested tty: dumb, height 0, width 0
SSH2 1: shell request
SSH2 1: shell message receivedSSH1: receive SSH message: [no message ID: variable *data is NULL]
SSH1: Session disconnected by SSH server - error 0x00 "Internal error"
Lab-ASA5515-X#
12-20-2012 08:23 AM
Have today updated to the latest Device Software updates and the backup of the 5525-X now works
For this intrested.
Ian
12-20-2012 11:07 AM
Thanks for the update. I installed the update on my lab LMS but it failed to fix my issue. The updated ASA package version is 7.1.
+ 5 for following up and posting the solution that worked for you.
Happy holidays.
12-21-2012 01:27 AM
HI,
I did not just apply the ASA fix, but all the latest updates that came out. So not sure which update fixed it.
I am running 8.6.1-5 on my ASA.
