ASA L2L VPN Tunnel Will Not Establish
TW80CJ5
Level 3
Level 3
Hello Everyone...
We are having a problem with one of our tunnels establishing a L2L connection. This tunnel has previously established with our current settings. We have rebuilt our crypto on both ends and verified the pre shared key. The tunnel will not form.
Please see the attached debugs of the following:
Debug crypto condition peer 192.168.10.145
Debug crypto ikev2 platform 255
Debug crypto ikev2 protocol 255
Debug crypto ipsec 255
Ideas / Suggestions ?
6 Replies 6
what is connected on the other side ? Post the configurations of both the ASA as well as the other device...
They are both Cisco ASA 5545X. Which part of the config are you interested in. It will take  some time to scrub it so anything specific I can get to you in the meantime....???
basically just the parts below (this is a sample of an IKEv2 L2L VPN):
crypto ikev2 policy 10
encryption aes-256
integrity sha256
group 19
prf sha256
lifetime seconds 86400
crypto ikev2 enable outside
object network OBJ-LAN-SITE_A
subnet 192.168.1.0 255.255.255.0
object network OBJ-LAN-SITE_B
subnet 192.168.2.0 255.255.255.0
access-list VPN-TRAFFIC-ACL extended permit ip object OBJ-LAN-SITE-A object OBJ-LAN-SITE-B
nat (inside,outside) source static OBJ-LAN-SITE-A OBJ-LAN-SITE-A destination static OBJ-LAN-SITE-B OBJ-LAN-SITE-B no-proxy-arp route-lookup
!LAN-
tunnel-group 100.100.100.1 type ipsec-l2l
tunnel-group 100.100.100.1 ipsec-attributes
ikev2 remote-authentication pre-shared-key 1234567
ikev2 local-authentication pre-shared-key 1234567
isakmp keepalive threshold 10 retry 2
crypto ipsec ikev2 ipsec-proposal VPN-TS
protocol esp encryption aes-256
protocol esp integrity sha-1
crypto map CRYPTO-MAP 1 match address VPN-TRAFFIC-ACL
crypto map CRYPTO-MAP 1 set peer 100.100.100.1
crypto map CRYPTO-MAP 1 set ikev2 ipsec-proposal VPN-TS
crypto map CRYPTO-MAP interface outside
I will work on getting you this information and will follow up with. Currently working with the ISP as they completed a circuit swap "upgrade" yesterday...
Thanks for the help!
TW80CJ5
Level 3
Level 3
Worked with ISP and they inadvertently changed our public AS number that we had in our configuration. Once they changed it back...the tunnel popped right back up. Thanks for the willingness to help!!!!!!
thanks for the update, good to kmow that everything is working now...
