ASR 1001-X VVM sensors voltage thresholds
net.curious
Hello everyone,
I would like to ask you some questions regarding some voltage issues.
1) where i could find voltage thresholds for the router ASR 1001-X
2) In my site, i have set up a monitoring tool, to monitor my network infra. So, I am receiving a lot of alerts, regarding the VVM sensors voltage. This monitoring tool, regarding ASR router has a max voltage threshold at 0,96 Volts, while as min voltage threshold has 0,71 Volts. I have checked my router logs, and i am not receiving any error log. With a "show env all" command, when router gets over 0,96 Volts, shows "state Normal"
Here is the output of the show command:
#sh environment all | i VVM 1: VX2
VVM 1: VX2       R0                Normal            1029 mV
Should i start digging that issue more?
Is there any place, that i could find which are the right thresholds, that i should enable in my monitoring tool.
Thank you and Regards!
net.curious
Hello everybody,
I am updating this post with an output of command "sh env table"
Sensor: VVM 1: VX2 Location: R0
Current State: Normal Reading: 849 mV
0-Normal Low:-2147483647 High:2147483647 Margin:0
Action:NONE Alarm:NONE
Poll:60000 Reminder:3600000
pos = post
what these "0-Normal Low:-2147483647 High:2147483647 Margin:0:" values mean ?
I need to figure out which are the best min and max voltage values in order to set my monitoring tool correct.
Thanks a lot!
