asr9001 doesn't respond to requests snmp arp
VooDDi
No response from 10.0.7.36 OID: .1.3.6.1.2.1.4.22.1.2
Presumably due to the large arp table
please help
5 Replies 5
marce1000
 - Check if snmp has been configured correctly on the ASR. snmp read-only community must be set and known for instance. Additional parameters do apply if snmp v3 is being used.
 M.
SNMP community is configured correctly. Other data is sent (statistics on interfaces and BGP). And earlier the ARP table was sent. But with an increase in the number of ARP entries, the router stopped responding.
 - Check current software version being used on the device. Use an advisory release, especially if the current installed version is dated.                                                          Check if the problem persists afterwards.
 M.
version asr9k-6.6.3
VooDDi
We realized that the table is not rendered due to its very large size. Now another question is how, using snmp, to request an arp table from a specific vrf and location
