Assign Priviledge levels with Radius
cmorris_DRI
I have a PIX 515E and a PIX 520 that i need to be able to assign priviledge levels to through radius, i have done it for the routers and switches using the shell:priv-level=15 on IAS, but it is not working for the PIX, is there another string that you have to put in for the PIX?
Thank you
Not applicable
djassi
Hi...
I'm not sure I can help you with your very old question, but I am pretty sure you can help me with mine, and eventually I might be able to help you with yours. :)
You mentioned that you have already configured your routers and switches to accept the shell:priv-level=15 command. I have tried, but the IAS reports a successful authentication but my router/switch says "Authorization Failed". Can you tell me how you configured your IAS policy to pass to the switch the priv-lvl=15 attribute.
I have the document "How to assign priviledge levels with TACACS+ and RADIUS" but it is not very clear on how to configure the Windows IAS Server. Thanks for any help you can give.
Djassi
All I did was create a group on our domain to put users in that I wanted to have access to the equipment and then created a policy under "Remote access policies" in IAS. In the group I specified the Attribute type "Windows-Group" and put the group in there that I wanted to have access to the equipment.
Then I just had to add the equipment under the clients folder and select "Radius-Standard". Hopefully this will work for you as well.
