06-06-2005 11:18 AM
Hi All
I am unable to find a reliable MIB that holds values for SCR for VBR / VBR-nrt on 8510.
I scanned ATM-traffic MIB in vain.
The purpose is to get PVC utilisation (Delta/SCR).
Any thoughts or pointers ?
Sam
06-10-2005 10:23 AM
You can try using the following MIBs to get the PVC utilisation values ..
1.3.6.1.4.1.9.9.66.1.1.1.1.3.33.0.65
1.3.6.1.4.1.9.9.66.1.1.1.1.4.33.0.65
Hope this helps.
06-12-2005 09:18 PM
Sadly this did not work, from the below returned message I assume the MIB is not supported by the IOS I am running.
no MIB objects contained under subtree.
Many thanks for ur help !
Sam
