Authentication Failure following LMS 3.1 > 3.2 Upgrade
samill222
Same symptom on 2 separate servers:
After the upgrade I try to login and get "Authentication failed. Please try again."
We've tried this with 3 separate admin level accounts.  We are normally configured to use ACS.
I did the typical installation with optional packages unchecked.
I tried restarting crmdmgtd and have tried running ResetLoginModule.pl (and restarting daemon manager).  No luck so far.  Any suggestions?
Joe Clarke
You may need to reset admin's password using the resetpasswd tool:
NMSROOT/bin/resetpasswd admin
