auto negotiation errors
choda489
Frequent Visitor
Frequent Visitor
I am trying to  give a UPLINK  to the Te0/0/24(10 Gig) ports of cisco router from the PTN device  with following configuration.  Assigned port went UP but  but invalid error have occurred while doing negotiation auto command lines. Pls help me.
***command used***
****errors occured***
@choda489,
The speed/duplex and negotiation commands are meant for copper media. The fiber-optic media always operate as 1000 Mbps with full auto negotiation
Best regards
10 Replies 10
M02@rt37
Hello @choda489,
Fiber-optic media ont Te 0/0/24?
Best regards
10Gig SFP
Hello @choda489,
Please provide the output of that command:
show interface Te0/0/24 transceiver
Best regards
OK @choda489
Interface need to be up/up to configure what you want.
Best regards
now interface is up/up  but still facing the same problems
@choda489
Coper or fiber? On your output, the media type is unknown.
Best regards
i have used fiber
@choda489,
Best regards
Is auto negotiation needed if i am using a fiber-optic media for 10000Mbps?
