Automatically Resetting DHCP Leases
stephen.pugh2
I am setting up a DHCP scope on a Cisco 4500X.  The DHCP will service new clients and provide a PXE boot set of options.  Once built the client will access a Windows based DHCP service.
I understand that the minimum DHCP lease duration is 1 day (24 hrs?). My question is, how can I clear the DHCP leases on a more regular basis say every 4 hours allowing me to use a smaller network IP range for the build network?
Thanks in advance!
Steve
2 Accepted Solutions
Marvin Rhoads
Try "clear ip dhcp binding". You can specify only a specific address or all ("*")
Reference
Glad to hear that worked.
It looks like the 4500X IOS-XE does include support for the kron command scheduler utility.
I've not used it personally but from the configuration guide, it looks like you should be able to do something like:
kron policy-list ClearBindings
cli clear ip dhcp binding
kron occurrence ClearDHCP in 04:00 recurring
Let me know if it works for you.
Marvin Rhoads
Reference
Hi Marvin
That worked, thank you.  Would you know how I could possibly automate this command to run every 4 hours?  Kron job perhaps?
Cheers,
Stephen.
Thanks again Marvin.  This will do the job nicely.
