07-06-2010 01:02 AM
Hi all,
I have connected 2 routers from each aux port to the other's console port for remote access in case of router failure.
Apparently, this generates a few odd behaviours:
- Sometimes if one of the routers reloads, it goes directly to ROMMON. If i reload again the router it boots ok
- I use TACACS authentication and authorization and i find in the failed attempts log a lot of "trash" entries, where the username looks like parts of messages from the login banner, or router console messages.
Has anybody else used this configuration and met these isues?
Do you know what types of messages are sent out the aux port during boot, and would they affect the other routers console port?
Thanks!
07-06-2010 06:32 PM
Make sure you have configured "no exec" under the aux port to prevent a local EXEC session from triggering a break on the console of the remote router.
07-07-2010 11:35 PM
Hi Joe,
Thanks for the support. I saw that this command solves both problems because now I don't see any more the junk entries in the failed attempts, and before this command they were plentiful.
Best Regards!
TC
