BACC 2.6 Clock Skew Errors
norrisdon
Community Member
I am receiving clock skew errors from my DPE's and was wondering what the possible causes are?
irisrios
Level 11
Level 11
This is usually indicative that the BACC Servers and DPE are out of sync by a timeframe larger than 5 minutes.
David Stanford
These errors usually indicate that the DPE, RDU and KDC server are greater than 5 minutes out of sync.
What are the current times on each of these devices? What are the timestamps on the CM/MTA's reporting?
You might want to have a look at the dpe logs as well.
Also, what is the current load on the DPE? What does a show dpe return?
