Backup Running-config Cisco Prime DCNM 6
Rodrigo Bezerra
Have configured DCNM to backup daily the running config starup. After I enabled the feature tacacs + The DCNM stopping backing up. But  when I logon as  the switch with the User created in tacacs_plus he can log in and run the command privilege 15 on the switch.
Someone would laguma idea how to solve this?
Rodrigo Bezerra
resolved!!
was necessary to add these attributes
Under the Custom Attributes tab, enter these values:
Attribute: cisco-av-pair
Requirement: Mandatory
Value: shell:roles*"network-admin vdc-admin"
