Bandwidth management on a switch
AESTRUSER
Hi All,
Does anyone have a list of the Cisco switches that are able to do bandwidth management? It seems a really hard thing to find. I'm after a switch that can manage bandwidth per port or IP and be part of a HA configuration. Doesn't need to be PoE or have many ports
Thanks in advance
Collin Clark
Almost all of their switches support your requirements. That being said, none of them that I know of, have a nice GUI for you to manage said ports. There a WebUI on the switch, but I don't use it and don't know much about it. You may be able to view some of the BW gauges on there. Wouldn't be to hard to write your own webUI if your really needed to.
