Bandwidth monitor using Netflow v5
Edson Vuma
Hi, all.
I actually have a router with sub-ifs...
I want to monitor the bandwidth with PRTG on each sub-if at the same time using Netflow.
I managed to make this configuration, but until now only accepts one sub-if each time.
Here is what I have on the router:
flow exporter PRTG
 description FLOW_EXPORTER_TO_PRTG
 destination 10.10.10.10
 source GigabitEthernet0/1.1
 transport udp 1000
 export-protocol netflow-v5
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1
 ip address <IP-ADDRESS>  <MASK>
 ip nbar protocol-discovery ipv4
 ip flow ingress
 ip flow egress
ip flow-export source GigabitEthernet0/1.1
ip flow-export version 5
ip flow-export destination 10.10.10.10 1000
This only works if I add the commands in red.
I created a new flow exporter, e.g.>
flow exporter PRTG_2
 description FLOW_EXPORTER_TO_PRTG_2
 source GigabitEthernet0/1.2
 transport udp 1000
And configured on the sub-if
interface GigabitEthernet0/1.2
 ip flow ingress
 ip flow egress
But, on the PRTG it doesnt import/receive the flow.
Because of the source command in RED above.
I use show ip flow and this is what it shows>
Router#sh ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       <IP-ADDRESS> (GigabitEthernet0/1.1)
    Destination(1)  10.10.10.10 (1000)
  Version 5 flow records
  50914209 flows exported in 1697147 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
Router#
Am I doing something wrong here?
Is there a way to activate the SOURCE simultaneosly?
P.S.: Without the commands in red it doesnt work.
P.S. 2: I tried to use the interface and not the sub-if
Any help?
Warm regards
/EV
-- Regards Edson Vuma
Dear Edson
The red lines which you added are legacy netflow commands. First you used NFN ( Flexible NetFlow). These are separate things and their operations do not correspond  each other.
About NFN:
You created Flow Exporter but missed the next step. You must enable flow monitor to complete your configuration; here's an example
flow exporter PRTG
source 192.168.1.1
destination 10.10.10.2
transport udp 500
flow monitor MONITOR1
record netflow ipv4 original-input
exporter PRTG
interface Ethernet 0/0
 ip flow monitor MONITOR1 input
Dear Edson
About NFN:
flow exporter PRTG
source 192.168.1.1
transport udp 500
exporter PRTG
Hi, Houtan H Larijani
Thanks for you reply...
It worked just fine.
Thanks.
But on the flow exporter config, it didn't allow me to use:
source <IP Address>
Only the interface...So I used the interface and it worked.
Here is what it allows me:
Router(config)#flow exporter PRTG
Router(config-flow-exporter)#source ?
  Async                          Async interface
  Auto-Template                  Auto-Template interface
  BVI                            Bridge-Group Virtual Interface
  CDMA-Ix                        CDMA Ix interface
  CTunnel                        CTunnel interface
  Dialer                         Dialer interface
  Embedded-Service-Engine        cisco embedded service engine module
  GigabitEthernet                GigabitEthernet IEEE 802.3z
  Group-Async                    Async Group interface
  LongReachEthernet              Long-Reach Ethernet interface
  Loopback                       Loopback interface
  MFR                            Multilink Frame Relay bundle interface
  Multilink                      Multilink-group interface
  Null                           Null interface
  Port-channel                   Ethernet Channel of interfaces
  Tunnel                         Tunnel interface
  Vif                            PGM Multicast Host interface
  Virtual-PPP                    Virtual PPP interface
  Virtual-Template               Virtual Template interface
  Virtual-TokenRing              Virtual TokenRing
  vmi                            Virtual Multipoint Interface
Few questions:
1. Can I use the "original-output" on the same flow monitor?
So, putting something like (check red):
flow monitor MONITOR_PRTG
 exporter PRTG
 record netflow ipv4 original-output
2. On the interfaces Im monitoring, I left like this:
 ip flow ingress
 ip flow egress
 ip flow monitor MONITOR_ENH input
Using the flow monitor, do I have to keep or remove the red commands above?
3. On the interface below for example, can I use the input with output at the same time?
Or the "input" itself works?
 ip flow ingress
 ip flow egress
Thanks again for your reply.
/EV
Q1- There's no limitation for using input and output simultaneously.
Q2- "ip flow egress/ingress" monitor old net flow command (ip flow-export) and are not related with your new configuration, "remove them".
Q3- using record input/output or both of them is up to you and what do you want to measure on interface.
Good luck
