Baseline compliance wildcard pattern
netadmincsm
I want to check for the existence of the following two logging serveur into my router devices.  I also want to make sure there's only those two logging server in my configuration
Here's my logging server
10.10.10.1
11.11.11.1
So I put those 3 lines in my compliance templates
+logging 10.10.10.1
+logging 11.11.11.1
-logging  [#.*#]
I figure out that the exclusion pattern doesn't work (-logging  [#.*#])
Is there a way to make a proper exclusion or should I always know the term that I want to exclude ?
Thanks !!!
10 Replies 10
Marvin Rhoads
I'm not sure if it's causing your issue, but I believe the "-" needs to be followed by a space. Please refer to the whitepaper on compliance templates here, page 27, which states:
All commands should have a space between the – or +. If there is no space, the commands are considered as comments and are ignored.
I take a look at my compliance template and I had the space after my plus or minus sign.   Any other Idea ?
Can you try one of the following :
+ logging 10.10.10.1
+ logging 11.11.11.1
- logging [#..*\..*\..*\..*#]
OR
- [# logging .*#]
Check and let me know the updates.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
I tried all of your exclusion pattern even Afroj's one but it doesn't works.  Let me show you what it does.
To make it simple I'll only use 3 devices
first router :
logging 10.10.10.1
logging 11.11.11.1
second router :
logging 10.10.10.1
third router :
logging 10.10.10.1
logging 12.12.12.1
If I run those exclusion patterns (- logging [#..*\..*\..*\..*#]) or (- logging [#.*#]) with the 2 + logging command I have the following :
first router (both colored green) :
  -logging 10.10.10.1
  -logging 11.11.11.1
second router (first colored red, second colored green):
  -logging 10.10.10.1
  +logging 11.11.11.1
third router (first two colored red, third colored green):
  -logging 10.10.10.1
  -logging 12.12.12.1
  +logging 11.11.11.1
If I run this exclusion patterns (- [# logging .*#) with the 2 + logging command I have the following :
first router (mark as compliant) :
second router (colored green):
  +logging 11.11.11.1
third router (colored green):
  +logging 11.11.11.1
***NOTE : It should have marked the third one with the line - logging 12.12.12.1 also but he doesn't ***
I remove the space just before the logging word of that one :
- [# logging .*#]
then all of the 3 exclusions give me the same things.
share your template with us.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
You got it.
It's the only thing I have in my template for now.  I have nothing more.
My thought are that prime can use the "include all" wildcard [#.*#] but only with inclusion line not exclusion.  Is that make sence ?
Hi ,
that  should not be the case..
share the output of below command from your device.
#show run | i logging
I run the same commands with Advance Template   , use the same commands i n GLOBAL mode
and it work fine.
can you check again.. I have attached one screen shot
Thanks-
Afroz
logging buffered 200000
no logging console
logging esm config
logging 10.10.10.1
logging 11.11.11.1
I took care of the screenshot you sent me but I'm still having the same issue.
Device NameLatest VersionCreated OnCommand(s) to Deploy
F.D.4182535484.R001.familiprix.net3Feb 14 2014 02:31:54
  -logging 10.10.10.1
  -logging 11.11.11.1
F.D.4182685326.R001.familiprix.net2Jan 28 2014 15:58:50
  -logging 10.10.10.1
  -logging 11.11.11.1
F.D.4182750941.R001.familiprix.net3Jan 28 2014 15:47:22
  -logging 10.10.10.1
  -logging 11.11.11.1
F.D.4182863301.R001.familiprix.net14Feb 16 2014 02:00:14
  -logging 10.10.10.1
  -logging 11.11.11.1
F.D.4182893069.R001.familiprix.net5Jan 28 2014 15:51:00
  -logging 10.10.10.1
  -logging 11.11.11.1
F.D.4183283358.R001.familiprix.net4Jan 28 2014 15:47:19
  -logging 10.10.10.1
  -logging 11.11.11.1
Hi ,
Use the ADVANCE Template option with these line
- logging [#.*#]
this should work
Thanks-
Afroz
