BBSM question with multiple vlans
xbalampanis
Hi all,
I want to use 2 different vlans in one switch. Is it possible? As i can see in one switch is possible to use only one vlan from the bbsm(webconfig-> network elements->switches-> switch1 -> snmp Password -> ip_address@clientsvlan.
Thanks in advance.
a-vazquez
Level 6
Level 6
Thanks for the answer, but i want 2 clients vlans and 1 management vlan. The only way that i can do this is to use 2 client vlans in every switch.
