Does anybody has issues with bbsm landinpage and windows xp sp2 clients with Windows FW active? It seems that the landing page doesnt work with fw enabled. if you disable it everything works. (i think its icmp?!?!) but in an hotspot enviroment you cant controll the clients
any solution for that?
regards
