Blocking Web Sites on Cisco ASA5510
meet_mkhan
Hi Experts,
Can Any one help in Blocking Web site for example Facebook on Cisco ASA5510
I used the below configuration on Cisco ASA5510 but did not blocked any web site
regex blockex1 "facebook\.com"
regex blockex2 "youtube\.com"
class-map type inspect http match-any block-url-class
match request header host regex blockex1
match request header host regex blockex2
policy-map type inspect http block-url-policy
parameters
class block-url-class
  drop-connection log
class inspection_default
policy-map global_policy
service-policy global_policy global
It won't work if the client is using HTTPS. Better use FQDN-based filtering with sites that don't use shared hosting:
object network FACEBOOK
  fqdn www.facebook.com
access-list INSIDE-ACCESS-IN extended deny ip any4 object FACEBOOK
dns domain-lookup inside
DNS server-group DefaultDNS
  name-server 10.10.10.10 ! your DNS-server
  domain-name company.intern
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Thanks for the reply.i dint find the command
:fqdn www.facebook.com" in  object network FACEBOOK
Can you please write the complete config in details
probably your ASA-version is to old, the fqdn-parameter was introduced in 8.4(2).
http://www.cisco.com/en/US/docs/security/asa/command-reference/f2.html#wp2058089
