Campus Manager Apps not accessible
sirbaughmf
I recently upgraded to LMS 3.2 on Solaris 9 and when I open the CiscoWorks Portal, the Campus related portlets never load...CM Data Collection Summary, CM Discrepancies Portlet, and CM User Tracking Summary Portlet.   Also, when I select the Campus Home, it times out and never opens.  Please help!
43 Replies 43
No, I cannot provide patches outside of TAC service requests.
I have upgraded and applied the patches...still seeing the same issue....data collection never finishes and UT never starts.
I have kicked off Data Collection again as a TACACS user and attached is a portion of the
ani.log.  There are unrecoverable databases errors, are these errors a problem??
The database errors are noy good.  Did you reinit ANI after the upgrade?  If you still have the TAC SR opened, have your engineer contact me.
I am now seeing that Campus is showing no neighbors for any devices.  Could the DCR be corrupted, can I reinit the CMF databases without loosing all the RME data?  Or would it be best to delete all devices from the DRC through the GUI and rediscover?
No, a reinit of cmf would destroy all data in all LMS applications.  After you installed 5.2.1 and applied the patches, did you reinit ANI?
Yes, I reinit the ani db after applying the patches. Yesterday I found that if I went into Topology Services and went to a user define group and performed a data collection on the small subset that some of them completed and the lines were redrawn, others seemed to failed and cause the app to hang. I watched the ani.log file and nothing stood out as being a problem. Once it hung up, I restarted ANIServer process and tried another group and it was ok...could info in the DCR be a problem?
Marcie Sirbaugh
This e-mail is unclassified based on the definitions provided in E.O.
I can't say what's happening in ANIServer at this point.  I would need to see a full thread dump.  That's why I suggested you have the TAC engineer contact me.  I can help them get the information I need to see why ANI is locking up.
I have sent the TAC engineer information including your name, he hasn't gotten back to me yet today, so I posted add'l info here....I will contact him again.
Marcie Sirbaugh
Also here is the dcrclient.log file with some interesting errors.
Marcie Sirbaugh
IRM/OPS/ENM/NED/EMS
Northrop Grumman
703.912.8019
Here is something from the wlseuhic.log:
WARNING: Server certificate chain does not end with trusted root cert!
2010/07/30 00:07:46 WlseUhic MESSAGE WlseDCRWrapper: DCR Server process initialization not yet completed...
2010/07/30 00:07:46 WlseUhic ERROR WlseDCRWrapper: Unable to fetch DeviceIDs from DCR
java.lang.NullPointerException
at com.cisco.nm.ani.server.vmpsadmin.wlse.WlseSMFGetWlseDevices.loadWlsesFromDCR(WlseSMFGetWlseDevices.java:73)
at com.cisco.nm.ani.server.vmpsadmin.wlse.WlseSMFGetWlseDevices.apply(WlseSMFGetWlseDevices.java:29)
at com.cisco.nm.ani.server.framework.EvalSMFApply.apply(EvalSMFApply.java:93)
at com.cisco.nm.ani.server.frontend.EvalGroup.executeMajorNode(EvalGroup.java:578)
at com.cisco.nm.ani.server.frontend.EvalGroup.apply(EvalGroup.java:656)
at com.cisco.nm.ani.server.frontend.EvalGroup.apply(EvalGroup.java:612)
at com.cisco.nm.ani.server.vmpsadmin.wlse.WlseTimeBaseImpl.performScheduledFunction(WlseTimeBaseImpl.java:36)
at com.cisco.nm.ani.server.frontend.AniTimeBaseImpl.execute(AniTimeBaseImpl.java:47)
at com.cisco.nm.ani.server.frontend.AniTimeLine.executeTimeBase(AniTimeLine.java:317)
at com.cisco.nm.ani.server.frontend.AniTimeLine.runSchedule(AniTimeLine.java:341)
at com.cisco.nm.ani.server.frontend.AniTimeLine.run(AniTimeLine.java:366)
at java.lang.Thread.run(Thread.java:595)
2010/07/30 00:07:47 WlseUhic MESSAGE WlseDBUpdate: Properties will be read from /opt/CSCOpx/campus/etc/cwsi/ANIServer.properties
Rogue MAC properties loaded from file: /opt/CSCOpx/campus/etc/cwsi/MACDetection.properties
Marcie Sirbaugh
Here is the last entry in the log when it seems to hang:
ERROR StpSMFGetSpanTreeDeviceInfo: Unable to fetch spanning tree type info from device xx.xx.xx.xx com.cisco.nm.lib.snmp.lib.SnmpValueException: Illegal Access. NoSuchObject being accessed as Integer.
2010/07/30 07:57:29 EvalTask-background-32 ani ERROR StpSMFGetStpInstance: unable to get stp device information
Validating License...
2010/07/30 07:58:50 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection
Seems to lose database connection
Marcie Sirbaugh
IRM/OPS/ENM/NED/EMS
Northrop Grumman
703.912.8019
Found log file /opt/CSCOpx/campus/utupgrade.log, here are the entries...
Version info found. version:5.1
Version: 5.1
Loading tables into DB...
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/EmbuUserTracking.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/EmbuUserTracking.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/DuplicateMACUTData.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/DuplicateMACUTData.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/HistoryHostTracking.data into DB
delete table SQL: delete from HistoryHostTracking
delete from HistoryHostTracking Success
Load table SQL: load table HistoryHostTracking from '/opt/CSCOpx/campus/etc/cwsi/HistoryHostTracking.data'
ERROR, unable to load Data file: /opt/CSCOpx/campus/etc/cwsi/HistoryHostTracking.data into DB
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/HistoryUserTracking.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/HistoryUserTracking.data is missing
Trying to load Data file: /opBM-BM-TBM-@t/CSCOpx/campus/etc/cwsi/embuPhoneTracking.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/embuPhoneTracking.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/wirelessUTTable.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/wirelessUTTable.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/ManualDevices.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/ManualDevices.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/devicestopoll.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/devicestopoll.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/RogueMAC.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/RogueMAC.data is missing
Trying to load Data file: /opt/CSCOpx/campus/etc/cwsi/NewMAC.data into DB
ERROR, Data file: /opt/CSCOpx/campus/etc/cwsi/NewMAC.data is missing
update fields SQL: update EmbuUserTracking set discrepancyEnabled=0, bestPracticesDeviationEnabled=0
update EmBM-BM-TBM-@buUserTracking set discrepancyEnabled=0, bestPracticesDeviationEnabled=0 Success
Data upgrade status isSuccessful?:false
Marcie Sirbaugh
And I am seeing this in the stdout.log file for every portal when I do my initial log in.
INFO: action: UIIController processActionForward does not have a screenID so no authorization was done for /WEB-INF/screens/portal/view/DiscrepancyBestPractices.jsp.
