can't get firewall sysloging to work
ronshuster
I am running a Linux syslog server (called syslog-ng) and I point the firewall to send all its syslog messages to that server. I believe that I don't have the correct syslog level configured on the firwall, because the syslog server is picking up all syslog messages from the rest of the CAT37505 switches, but not the firewall.
Here's my firewall logging config:
logging enable
logging timestamp
logging console informational
logging buffered notifications
logging trap errors
logging asdm informational
logging mail emergencies
logging facility 16
logging host Inside 192.168.200.54 format emblem
logging permit-hostdown
I can ping this IP address, the routing is ok, nevertheless no syslog messages are reaching the syslog server.
Please assist
Joe Clarke
Is it that no syslog messages are making it to the server, or is syslog-ng ignoring them? Are you certain the firewall is generating messages? Your trap severity is set to errors which mean only messages level 3 and lower will be sent as syslogs.
scristian
try to put this
snmp-server enable traps syslog
That did the trick:
All the messages went to the buffer and console and none made it to the syslog server, it is now working.
Thanks!!!
