Cannot ping over switches (VLANs configured)
Pietro955
Hi guys, this is my firts post here, I'm studying for the CCNA exam and now I'm learning how to use vlans. As the title says I cannot ping PCs or other objects over the first switch but I'm still able to ping sub interfaces. This is the configuration, thanks for your time:
Switc0 config:
Current configuration : 1687 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 20
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
switchport access vlan 30
interface FastEthernet0/16
switchport access vlan 40
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
switchport access vlan 50
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport mode trunk
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router0 config:
Current configuration : 1187 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.0
interface FastEthernet0/0.3
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.0
interface FastEthernet0/0.4
encapsulation dot1Q 40
ip address 172.16.40.1 255.255.255.0
interface FastEthernet0/0.5
encapsulation dot1Q 50
ip address 172.16.50.1 255.255.255.0
interface FastEthernet0/0.6
encapsulation dot1Q 60
ip address 172.16.60.1 255.255.255.0
interface FastEthernet0/0.7
encapsulation dot1Q 70
ip address 172.16.70.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Switch1 config:
Current configuration : 1149 bytes
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch2 config:
Current configuration : 1409 bytes
version 12.2
hostname Switch
switchport access vlan 60
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch3 config:
Current configuration : 1358 bytes
version 12.2
hostname Switch
switchport access vlan 70
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
So far I spot issue:
Vlans are missing on switches; even switch that only passing others traffic (trunking) must have vlan id that should pass over. in other words, if vlan x does not exists on switch, vlan x is removed from trunking. Sw 0 missing vlan 60; switch missing all of them.
7 Replies 7
Martin L
do PCs have default gateways set up?  like all PCs in vlan 10 should point to  172.16.10.1 and be on  172.16.10.x/24 network.
if this is in Packet tracer, please zip it and attach here, it is easier/faster to spot issue
Regards, ML
**Please Rate All Helpful Responses **
Yes... I can ping the pcs that are connected to the same switch as the router is connected, but can't ping over the first switch
Thanks, I really appreciate. I would like to know why tho. If you have a book or some PDF files to read about it would be nice, because in the slides from where I'm studying it's not mentioned, and I'd like to know how VLANS and protocols works in the deep. Thanks for your answer :)
I think you need ccna book to pass the exam; the one by W. Odom is good one.
I look for source for your question"Why vlan x is removed from trunking?"
but compare show interface trunk before and after a "fix" was apply
Switch#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/22      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/22      1-1005
Port        Vlans allowed and active in management domain
Fa0/22      1,70
EDIT: this switch will not let traffic in vlans 10 thru 60 pass over its trunks; only vlan 1 and 70
Here is the zip, thanks mate
This is SW1 after the fix
