cant ping to default gateway
daniel4579329
hi
i am learning to ccna and i try to do subinterface between vlans and when i have couple of pc's (with different vlans) i can ping between them, but when i have pc's connect to a switch that connect to a swich and then connect to a router i cant oing to the default gateway
thanks for the help (:
20 Replies 20
what i understood from your post is, when you connect user pc with the switch connected to router you are able to communicate between different VLan. once u add another  switch to the above topology and bring all users to the second switch you are not able to ping. can you check the port configuration  between the second and new switch it should be trunk.
And check  port status.
Response Signature
Martin L
You must have trunks between those switches and switch to Router;
Also, those switches (all switches on the path) should have vlan x,y,z in database that those PCs belong to.  If PC is in access vlan x, but upstream switch does not have vlan x in its database, traffic x is dropped from trunk links.
Regards, ML
**Please Rate All Helpful Responses **
Richard Burts
We do not have much detail to work with to understand the issue. I think I understand that some PC is connected to a port in switch 1, switch 1 is connected to a port in switch 2, and switch 2 is connected to a router. Please help us to understand better by answering these questions and providing the requested information:
- is the PC connected to an access port in switch 1? If so the access port is in what vlan? Which port is the PC connected to?
- what is the IP address, mask, and default gateway of the PC?
- are there multiple vlans on switch 1? If so what other vlans exist on switch 1?
- what port on switch 1 connects to what port on switch 2? Is this connection an access port to access port or is the connection configured as a trunk?
- what port on switch 2 connects to the router? Is this connection configured as a trunk?
- please provide the output of these commands on both switches
show interface status
show interface trunk
- please provide the output of these commands on the router
show ip interface brief
show arp
Rick
Tanks for the reply
i think this photo will show more information
if still does not work, attach your PT file here (must be in a zip format)
how do i make it a zip file
about the other questions
- the default gateway of each vlan is for example vlan 120 = 192.168.120.0  D.G. -192.168.120.1
- output of the left switch (in the photo)
Switch#show interfaces status
Port Name Status Vlan Duplex Speed Type
Fa0/1 notconnect 1 auto auto 10/100BaseTX
Fa0/2 connected 120 auto auto 10/100BaseTX
Fa0/3 connected 120 auto auto 10/100BaseTX
Fa0/4 connected 120 auto auto 10/100BaseTX
Fa0/5 connected 120 auto auto 10/100BaseTX
Fa0/6 connected 120 auto auto 10/100BaseTX
Fa0/7 connected 111 auto auto 10/100BaseTX
Fa0/8 notconnect 1 auto auto 10/100BaseTX
Fa0/9 notconnect 1 auto auto 10/100BaseTX
Fa0/10 connected 1 auto auto 10/100BaseTX
Fa0/11 notconnect 1 auto auto 10/100BaseTX
Fa0/12 notconnect 1 auto auto 10/100BaseTX
Fa0/13 notconnect 1 auto auto 10/100BaseTX
Fa0/14 notconnect 1 auto auto 10/100BaseTX
Fa0/15 notconnect 1 auto auto 10/100BaseTX
Fa0/16 notconnect 1 auto auto 10/100BaseTX
Fa0/17 notconnect 1 auto auto 10/100BaseTX
Fa0/18 notconnect 1 auto auto 10/100BaseTX
Fa0/19 notconnect 1 auto auto 10/100BaseTX
Fa0/20 notconnect 1 auto auto 10/100BaseTX
Fa0/21 notconnect 1 auto auto 10/100BaseTX
Fa0/22 notconnect 1 auto auto 10/100BaseTX
Fa0/23 notconnect 1 auto auto 10/100BaseTX
Fa0/24 notconnect 1 auto auto 10/100BaseTX
Switch#show interfaces trunk
Port Mode Encapsulation Status Native vlan
Fa0/10 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/10 1-1005
Port Vlans allowed and active in management domain
Fa0/10 1,111,120
Port Vlans in spanning tree forwarding state and not pruned
Fa0/10 1,111,120
output of the right switch
Fa0/1 connected 1 auto auto 10/100BaseTX
Fa0/2 connected 80 auto auto 10/100BaseTX
Fa0/3 connected 80 auto auto 10/100BaseTX
Fa0/4 connected 80 auto auto 10/100BaseTX
Fa0/5 connected 111 auto auto 10/100BaseTX
Fa0/6 notconnect 1 auto auto 10/100BaseTX
Fa0/7 notconnect 1 auto auto 10/100BaseTX
Fa0/1 on 802.1q trunking 1
Fa0/4 on 802.1q trunking 1
Fa0/1 1-1005
Fa0/4 1-1005
Fa0/10 1-1005
Fa0/1 1,80,111
Fa0/4 1,80,111
Fa0/10 1,80,111
Fa0/1 1,80,111
Fa0/4 1,80,111
Fa0/10 1,80,111
output on the router
Router#show ip interface brief
FastEthernet0/0 unassigned YES manual up up
FastEthernet0/0.80 192.168.80.1 YES manual up up
FastEthernet0/0.90 192.168.90.1 YES manual up up
FastEthernet0/0.100 192.168.100.1 YES manual up up
FastEthernet0/0.110 192.168.110.1 YES manual up up
FastEthernet0/0.111 192.168.111.1 YES manual up up
FastEthernet0/0.120 192.168.120.1 YES manual up up
FastEthernet0/1 unassigned YES unset administratively down down
GigabitEthernet0/2/0 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
Router#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.10.1 - 0003.E454.9701 ARPA FastEthernet0/0
so far I see missing vlan 120 on right switch based on Output of Port Vlans allowed and active in management domain
In Windows, select file, right click, Send To, Compressed Zip file.  Otherwise you can use free 7-zip (choose zip format)
not sure about MACs and Linux but you should have some sort of compressor like WinZip
Regards, ML
please share PT file even if you fix it; looks good!
i added a pc on the right switch with ip and mask and put it on vlan 120, now everything look good but i feel like i didnt understood the problem and how it got fix can you explain to me ?
In order for a switch to let pass vlan x traffic thru: 1. switch must have vlan x present in its database (sh vlan). Either Add vlan x to config manually Or switch gets it via VTP.
2.  vlan x must be active (not shut but PT does not have such option, so all are not shut)
and 3. vlan x must be allowed on trunks.
you do not need to have PC in vlan x connecting to that switch that would just pass such vlan traffic.  Note: that command switchport access vlan x  automatically adds vlan x to vlan database.
see show interface trunk and look for vlan x in section Port Vlans allowed and active in management domain (re:1)
Re: 3, look at section Vlan allowed on trunk - it lists vlan that were not manually prohibited (removed) by admin.
Regards, ML
i didnt quite understand " (not shut but PT does not have such option, so all are not shut) "
and i cant make the vlan be in up/up without add a pc on on the switch attached to that vlan
" up/up" is true for interface vlan x which is called SVI.  but SVI is not needed here (switch just passing traffic thru) and does not count for for vlan to be active or inactive (shutdown);
down below you have sw 6, sw 9, sw 5, PC 111.4 and 111.5 are on same network/subnet.  Ping and fix it w/o adding any PCs or SVI on sw9
Side Note: PT does not have all options like shutdown vlan. that's why I wrote "active" not shutdown. see attached text file, "before and after" example where I shutdown vlan 50,
and if VTP mode is transparent, show run will show you vlan list:
vlan 10,20,30,40
vlan 50
shutdown
Regards, ML
