Cat6500 temperature
nomuramasahide
catalyst 6500 is saying that the max. temp. is 40 C from datasheet.
so I checked my device temperature.
switch#show env temperature
  VTT 1 outlet temperature: 33C
  VTT 2 outlet temperature: 32C
  VTT 3 outlet temperature: 32C
  module 1 outlet temperature: 39C
  module 1 inlet temperature: 33C
  module 1 aux-1 temperature: 42C
  module 1 aux-2 temperature: 40C
  module 1 asic-1 temperature: 66C
  module 1 asic-2 temperature: 61C
  module 1 EARL outlet temperature: 38C
  module 1 EARL inlet temperature: 35C
  module 2 outlet temperature: 37C
  module 2 inlet temperature: 31C
  module 2 aux-1 temperature: 38C
  module 2 aux-2 temperature: 37C
  module 2 asic-1 temperature: 62C
  module 2 asic-2 temperature: 57C
  module 2 EARL outlet temperature: 33C
  module 2 EARL inlet temperature: 32C
  module 3 outlet temperature: 37C
  module 3 inlet temperature: 30C
  module 3 aux-1 temperature: 36C
  module 3 aux-2 temperature: 37C
  module 3 asic-1 temperature: 62C
  module 3 asic-2 temperature: 57C
  module 3 EARL outlet temperature: 33C
  module 3 EARL inlet temperature: 31C
  module 4 outlet temperature: 37C
  module 4 inlet temperature: 32C
  module 4 aux-1 temperature: 36C
  module 4 aux-2 temperature: 37C
  module 4 asic-1 temperature: 61C
  module 4 asic-2 temperature: 57C
  module 4 EARL outlet temperature: 32C
  module 4 EARL inlet temperature: 30C
  module 5 outlet temperature: 37C
  module 5 inlet temperature: 30C
  module 5 device-1 temperature: 33C
  module 5 device-2 temperature: 35C
  module 5 asic-1 temperature: 54C
  module 5 asic-3 temperature: 41C
  module 5 asic-4 temperature: 53C
  module 5 RP outlet temperature: 32C
  module 5 RP inlet temperature: 32C
  module 5 EARL outlet temperature: 34C
  module 5 EARL inlet temperature: 28C
I found several asics are very hi temperature.
are they acceptable ?
6 Replies 6
Leo Laohoo
Enter the command "sh env al".  If no additional errors then you are fine.
thanks leolaohoo
I'll check show env all.
Do you know that if  asics temperature were over 40C on "show env temperature", we could get cisco's supports ?
so CCO said " Certified for operation: 32° to 104°F (0° to 40°C) " on http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/01over.html
The temperature in the data sheet talks about the OUTSIDE temperature relative to the switch.  The output you've shown is from the INSIDE of the switch.
thanks leolahoo.
I do understand!
thank you for your kidness.
yusifmusayev
Can anybody explain what is VTT and EARL temperature?
Mostly every important modules in these modular switches like 6500 has temperature sensors to guage there temperatures and provide alerts in time.
EARL stands for Enhanced Address Resolution Logic. It is gives the 6500, the ability to do packet forwarding in hardware. EARL is nothing but a set of ASICs or CHIPs that does forwarding lookups at hardware level. The same job that a CPU or Proccesor does. But by doing forwarding lookups in hardware and not involving the CPU, helps us to achieve the Millions Packet/Sec rate.
The VTT(voltage termination) module are three replaceable voltage termination (VTT) modules (WS-C6K-VTT-E=) that provide reference voltage for bus signals.
These temperature sensors are for these two hardware modules/ASICs to monitor.
-Thanks
Vinod
**Encourages contributors. RATE them **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
