Catalyst 3650 unsupported protocol
DanGab
After using express set up on a new 3650 switch, I try to access the webui, I get a prompt for secure access. If I chose yes I get the following message: xx.xx.xx.xx uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
If I choose non secure connection, I can see the dashboard/port status etc. but cannot make changes. Any help would be appreciated.
Mark Elsen
 - Available ciphers between secure server and switch do not match, try other browser or else enable   TLSv1.1 & TLSv1.2. You may verify these by  nmap --script ssl-enum-ciphers <l3_switch_ip_address>.  or show  ip http server all (on the switch)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
