CBD Application verification failure
miriamc
 Trying to add again a CBS switch to our Cisco Business Dashboard setup but keeps failing with verification failure, any help?
in addition to @Ruben Cocheno suggestion, make sure the device credentials are correct (as described in the document linked below)...
https://www.cisco.com/c/en/us/support/docs/smb/cloud-and-systems-management/Cisco-Business-Dashboard/kmgmt-2215-configure-device-credentials-cbd.html
Ruben Cocheno
@miriamc
Check the certificate as they must match
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@miriamc
