CCP Java error
snoker1989
Hi all
I have installed Cisco Configuration Professional 2.8 and everything seemed fine while installing, the requirements were all checked correctly (flash, java, IE, etc).
But when I try to run it I get the following error:
"Cisco Configuration Professional requires Internet Explorer Java plug-in 1.6.0_11 or above. Please instal Java Runtime Environment before running the application."
I have Java 8 with the "-Xmx256m -Dsun.java2d.d3d=false" runtime parameter and the next-gen Java plugin feature unchecked. I also tried running it as admin.
I read that java 8 had some issues, and tried again with java 7 with the same result.
Anyone has any idea about how to fix it?
I'm using windows 7 64-bit
farshad110
hey man
Could you resolve your problem ??
Emaill me please : alaei.farshad1991@yahoo.com
