cdspTotalChannels MIB is not getting listed when MIB Loaded in HUM
netops044
In HUM, we loaded the MIB CISCO-DSP-MGMT-MIB but it is not listed all the MIB instances below DSP status Entry. We are getting the OID for InUse channels and Active Channels but not getting Total channels object listed. Are we missing any thing which is causing this problem.
Below URL shows the Total Channel usage OID but the same is not getting listed when the MIB is loaded, now how do we get the same listed to plot graph for the same.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.86.1.2.1.1.6
Also can we add all the DSP instance value to get the complete channel available in any MGW.
ramanan
Joe Clarke
The problem is the type of the cdspTotalChannels object. Try changing the the type of the object from Unsigned32 to Gauge32 in the MIB, then reload the MIB. Then you will see the object.
Can you please guide us on how to change the same.
ramanan
Use this version.
