change audit report issue and config archive
nawas
Level 4
Level 4
I run a 24 hour change audit report and I see that every device gets updated everyday due to ntp-clock-period change, for instance I see two entries when I compare the configuration.
version 1--ntp clock-period 36029426
version 2--ntp clock-period 36029429
Anyone seen this? I'm running rme 4.0.5 on Solaris 9.
David Stanford
You'll need to exclude the commands:
Log in to LMS:
Go to RME -> Admin -> Config Management -> Archive Management -> Exclude Commands
Select the device type in the list on the left then in the right pane called
Exclude commands, write ntp clock-period, if there are multiple commands
you'll notice they are comma separated so just add this to the end of the
list ,ntp clock-period after this you'll stop the ntp changes from
triggering the config fetches,
