Change NE password using Cisco Prime Infrastructure
ndahemmy
I'd appreciate if someone can share with me the procedure to change user's  password for the network devices using Cisco Prime Infrastructure.
Network devices includes Catalyst 9300, 9500 and ASA5506
Thank you
 - Check if this can help :
            https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/user/guide/bk_CiscoPrimeInfrastructure_3_9_0_UserGuide/create_templates_to_automate_device_configuration_changes.html#task_DB91E521968842FCBADEC11CC81BA228
 M.
Mark Elsen
  - You can't because that leads to a race condition , in the sense that Prime uses device credentials too for administrative access,
 M.
I am not changing admin user password. I need to change another username password
 M.
