03-11-2006 11:38 PM
I have 1900/1924 switches in my Network and its OID is 1.3.6.4.1.9.5.18 and the switch Device pakege in RME is not available, can any one help me out how can i take the archive of these devices.
03-16-2006 02:33 PM
RME and CM 4.0.2 have support for the 1912, 1924, and 2820 devices.
03-18-2006 12:50 AM
Yes campus manager 4.0 has the Support for the device and it is showing it green but how can i take the archive configuration of the 1900 and 1924 Device.
05-22-2006 12:46 AM
4.04 has support for the 1924 but it seems only as from 9.00.07 software release according to supported devices.
I have successfully pulled archives with 9.00.06 software.
I was really supprised that with the upgrade to 4.0 (3) RME,suddenly support for these switches changed. With RME 3.0 I was able to archive.
Hope this will help.
Bas Kokken
05-22-2006 05:21 AM
Somewhat more detail:
a 1900c with 9.00.06 Enterprise software lets me archive.
A 1924a with standard software does not let me archive.
It complains about the telnet login when doing check credentials
Anyone know how to enter credentials for a 1924A switch in Ciscoworks CS 3.03 / RME 4.04
05-22-2006 07:41 AM
CiscoWorks only supports the 1900's running Enterprise code and not standard
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_5/e3_5.htm
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0_3/sdt/rme403.htm
05-22-2006 10:38 PM
I could not find this in the RME 4.0 link but. There is another note on the web about a migration / upgrade planner. This document states, as you mentioned, that RME only supports the commandline capable 1900 Enterprise switches
I believe the supported devices document for RME 4.04 is not too clear: only by looking at the OID, you can find out it is the enterprise 1900 that is intended in this document.
Bas Kokken
