08-03-2023 04:22 PM
Is there a way to check the temperature of a 2960x temperature history via CLI command? Not just the current temp, the past logs of temperature as well.
08-06-2023 05:35 AM
- Not possible , but if you use network manager software you could query the temperature of the switch at regular intervals with SNMP and plot it ,
M.
08-06-2023 09:21 AM
I'd like to suggest Cisco EEM (Embedded event manager) as an applet that
.. every x minutes ...
using "show logging | inc <your-syslog-mnemonic>" you can check the history, or even better at a central syslog server...
... using SNMP with a "purpose built" central snmp manager software might work "out of the box" of course...
