Cisco 3164q management LAN IP from DHCP
calee1234
hi there,
is there a way to configure the management LAN IP from DHCP (not a fixed IP)?
I tried to configure the IP 0.0.0.0/16 but there is an error message.
switch#
switch# configure
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)#
switch(config)# interface mgmt 0
switch(config-if)#
switch(config-if)# ip address 0.0.0.0/16
% Illegal IP address
switch(config-if)#
switch(config-if)#
Deepak Sukhiya
Hi Calee1234,
Your post has landed in the wrong technology section. I would request you to please raise the post in the correct section.
Deepak
Predrag Jovic
Level 3
Level 3
Try
interface mgmt 0
 ip address dhcp
