OID for IPSLA ICMP jitter
sathvik k v
Level 3
Level 3
I have configured a IP sla with ICMP jitter as pasted below.I would like to collect latency,jitter and loss using snmp. should i use object rttMonJitterStatsEntry(1.3.6.1.4.1.9.9.42.1.3.5.1) or ciscoIpSlaJitterMIBObjects(1.3.6.1.4.1.9.9.635.1). Also would like to know the difference between them.
ip sla ABC
icmp-jitter x.x.x.x source-ip y.y.y.y num-packets 50 interval 300
ip sla schedule ABC life forever start-time now
IOS : c1900-universalk9-mz.SPA.152-2.T.bin
Sathvik K V
AFROJ AHMAD
Hi ,
you use the
CISCO-RTTMON-ICMP-MIB<http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step
=2&mibName=CISCO-RTTMON-ICMP-MIB
> to collect data and details for ICMP-Jitter operation. This MIB is an extension to the CISCO-RTTMON-MIB for ICMP  operations. The ICMP Jitter operation provides capability to measure metrics such as RTT (Round Trip Time), Jitter, packet loss, one-way latency by sending ICMP TIMESTAMP stream to the destination devices. First of all to know the index/details of the configured operations we can determine it through : rttMonLatestIcmpJitterOperTable A table which contains the status of latest ICMP Jitter operation. Each conceptual row corresponds to a ICMP jitter probe defined in rttMonCtrlAdminTable and has same index as rttMonCtrlAdminTable. For further details we can use: rttMonLatestIcmpJitterOperEntry<http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?obj
ectInput=rttMonLatestIcmpJitterOperEntry&translate=Translate&submitValue=SUBMIT&submitClic
ked=true
1.3.6.1.4.1.9.9.42.1.5.4.1.41    Destination to Source Latency one way Min
1.3.6.1.4.1.9.9.42.1.5.4.1.48    Destination to Source Latency one way Avg
1.3.6.1.4.1.9.9.42.1.5.4.1.42    Destination to Source Latency one way Max
1.3.6.1.4.1.9.9.42.1.5.4.1.37    Source to Destination Latency one way Min
1.3.6.1.4.1.9.9.42.1.5.4.1.47    Source to Destination Latency one way avg
1.3.6.1.4.1.9.9.42.1.5.4.1.38    Source to Destination Latency one way maxi
1.3.6.1.4.1.9.9.42.1.5.4.1.4     Latest RTT in ms
1.3.6.1.4.1.9.9.42.1.5.4.1.1     Latest ICMP-Jitter Number Of RTT
1.3.6.1.4.1.9.9.42.1.5.4.1.4     RTT Min
1.3.6.1.4.1.9.9.42.1.5.4.1.5     RTT Maxi
1.3.6.1.4.1.9.9.42.1.5.4.1.26    rttMonLatestIcmpJitterPktLoss
1.3.6.1.4.1.9.9.42.1.5.4.1.32    rttMonLatestIcmpJitterPktLateA
1.3.6.1.4.1.9.9.42.1.5.4.1.33    rttMonLatestIcmpJitterMinSucPktL
1.3.6.1.4.1.9.9.42.1.5.4.1.34    rttMonLatestIcmpJitterMaxSucPktL
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
6 Replies 6
AFROJ AHMAD
Hi ,
you use the
ked=true
Thanks-
Afroz
Afroj,
Could you help with the OID for UDP jitter. I'm looking fo statistics for latency,jitter and packet loss(DS,SD).
Sathvik K V
Hi Sathvik,
MIB is :
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-RTTMON-MIB
OID for Number of RTT -  1.3.6.1.4.1.9.9.42.1.3.5.1.4
to get the Index no: rttMonCtrlAdminIndex
rttMonJitterStatsOWSum2SDLow
rttMonJitterStatsOWSum2SDHigh
rttMonJitterStatsOWSum2DSLow
rttMonJitterStatsOWSum2DSHigh
rttMonJitterStatsNumOfOW
rttMonJitterStatsOWMinSDNew
rttMonJitterStatsOWMaxSDNew
rttMonJitterStatsOWMinDSNew
rttMonJitterStatsOWMaxDSNew
for packet :
rttMonJitterStatsPacketMIA
    rttMonJitterStatsPacketLossSD
    rttMonJitterStatsPacketLossDS
    rttMonJitterStatsPacketLateArrival
    rttMonJitterStatsPacketOutOfSequence
    rttMonJitterStatsNumOfRTT
Thanks-
Afroz
Thank you
Hello sathvik,
I am new to network monitoring and finding very difficult to measure those you have measured. Can you please help me.
I have installed solarwinds NPM, I know how to configure snmp., but I don't know much about OID. Can please vaguely explain me that.
First you need to understand how SNMP works, So every device will have a MIB which contains OID. MIB is a tree structure which can be parsed to get values. You need to spend some time reading may be 4-5 hours for basic undertsanding.
http://www.cisco.com/networkers/nw04/presos/docs/NMS-1N02.pdf
-Sathvik
