cisco 3640 nm-1fe t1 module diable when router crashed
lucianhunt
CISCO_3640ROUTER#show diag 3
Slot 3:
Unknown (type 0) port adapter, 0 ports
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 0.0 Board revision UNKNOWN
Serial number 0 Part number 00-0000-00
Test history 0x0 RMA number 00-00-00
EEPROM format version 0
EEPROM contents (hex):
0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x30: 00 00 00 00 00 00 00 00
umedryk
Level 5
Level 5
If you had a syslog server enabled before crash, you could check for the syslog messages...
i never had the chance to enable syslog i set the ip on the fastethernet mod and the next thing i know it crashed.i have tried to diff ios the card in show diag say unknown and eeprom is all 00.i look on the cisco site they use ios 12.3 (4)t i don't have a contract with cisco just a lot of the routers.i have search on google and seen a lot of people have this peoblem , i think it is a ios issue after all the research i have done. i can't access the bug tool kit on cisco , because i don't have the access level.thank's for the help.
