CISCO 3750X stacking for 5 switches , only 4 switches are coming in stack
nabil.shaikh
Dear All,
I have 5 cisco 3750X switches ,but only 4 switches coming up 5 switches i am unable to see .
Connection for the switch :Please find the attached snapshot for the stack data connection .
Also find the snapshot for the stack power connection .
Please provide your assistance and support to overcome this issue .
6 Replies 6
Leo Laohoo
Data from stack_data_connection.jpg & stack_power_connection.jpg are useless.
show_switch_snapshot.jpg is showing the stack were all powered up simultaneously.  Have you tried checking the power for switch stack #5?
Marvin Rhoads
The 3750-X models have a data stack and power stack. The power stack is limited to four switches, so a fifth one would have to be in a separate power stack.
You can form a data stack however with up to 9 members. When you plug into console on switch #5, what does it show for "show switch detail".
Dear Marvin,
Thanks for your reply.
is my connection provided in attachment for data stack are ok .
i login to Switch # 5 through console
following is the result :--
switch: ?
           ? -- Present list of available commands
         arp -- Show arp table or arp-resolve an address
        boot -- Load and boot an executable image
         cat -- Concatenate (type) file(s)
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
  flash_init -- Initialize flash filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
      memory -- Present memory heap utilization information
    mgmt_clr -- clear management port statistics
   mgmt_init -- initialize management port
   mgmt_show -- show management port statistics
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
        ping -- Send ICMP ECHO_REQUEST packets to a network host
      rename -- Rename a file
       reset -- Reset the system
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
      set_bs -- Set attributes on a boot sector filesystem
   set_param -- Set system parameters in flash
       sleep -- Pause (sleep) for a specified number of seconds
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
switch: version
C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
Compiled Tue 26-Apr-11 06:59 by abhakat
switch: boot
Loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin: no such file or directory
Error loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
All other 4 switches i can see in stack but not these switches and also the status light for this switches is blinking green  please provide your assistance .
Your switch is not booting IOS and is is the pre-boot condition known as "rommon". (Read Only Memory MONitor)
This is usually due to a deleted or corrupted IOS image. You need to recover the image and boot the IOS fully for the switch to be able to join the data stack. Here is a reference to the commands available to you in rommon mode.
Use dir to figure out what you have and then copy to move the files into flash (if necessary). Then boot using the restored image.
Dear Marvin ,
can you please provide me the link to download c3750e-universalk9-mz.122-58.SE2.bin
Here's the link.
You will need a support contract associated with your cisco.com userid to be eligible to download the image.
