Cisco 4451 Subslot Configuration
markhughes
I installed a module in a 4451 Router.  I can see the new subslot as shown below.  I have activated it as shown by the last command.  The issue is if I do a show interface... command I can't see it there, can't see it with a show run and can't get to it with a conf t: int gi 1/0....
Need assistance in locating the interfaces so I can configure this new module.
CH01-INET-4451#show diag subslot 1/0 eeprom
SPA EEPROM data for subslot 1/0:
Product Identifier (PID) : SM-X-16G4M2X
Version Identifier (VID) : V02
PCB Serial Number : FOC2....
Hardware Revision : 1.0
CLEI Code : INUIAH0EAB
CH01-INET-4451#show diag subslot 1/0 eeprom detail
EEPROM version : 4
Compa.....
CH01-INET-4451#hw-module subslot 1/0 start
Mark Elsen
            >...CH01-INET-4451#hw-module subslot 1/0 start
   - Check the logs on the 4451 after using this command too
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
does the module show up when you issue the 'show platform' command ? Did you try to connect with the commands below (depending on your slot/subslot):
4451# hw-module session slot/card
4451# hw-module session 0/1 endpoint 0
Check the document linked below for reference:
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/dam/en/us/td/docs/routers/access/interfaces/sm/hardware/installation/guide/SMX16G4M2X-book.html.xml
