CISCO 5505 ASA Lost userid/password
vvaradarajan
a. Anyway to recover userid/password on CISCO 5505 ASA? The original network person quit suddenly.
b. There is a 'reset' button - haven't tried it as I do not want to lose the settings. Will pressing this cause loss of settings?
Thanks..Any response will be great..-Vasan
Collin Clark
Collin Clark
Follow the steps from this link and you should be good to go.
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1058131
Hope that helps.
Great Sir! Thanks..It worked and did not disturb the original configuration..
Vasan
If Collin has provided a solution and your problem is resolved it would be appropriate to use the rating system, to click the check mark indicating that your problem is resolved, and perhaps to assign a rating to Collin's response.
Rick
Rick
