Cisco 6500 series..netflow configuration
linker.team
In Cisco 6509, while setting the flow mask to interface-full mode I get the following error..
% Unable to configure flow mask for ip protocol: interface-full. Reset to the
default flow mask type: none
Is it a limitation?
Jan Nejman
Level 3
Level 3
some features as NAT may require certain flow mask. Do you using some special features (NAT,IPSec,bridging)?
Please, could you send me your current flowmask. (show mls netflow flowmask)
or in better case the full configuration.
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Hi Jan,
Here are the outputs.
#sh mls netflow flowmask
current ip flowmask for unicast: null
current ipv6 flowmask for unicast: null
Also SUP 720 runs 12.2(18)SXF8 IOS.
Do you have any insights on this.
Raj
