Cisco ASA EEM Variables
Jason Kopacko
Level 4
Level 4
I have an EEM applet that nightly makes a backup of all my ASA firewalls. I have to, daily move the config backups so the next backup doesn't just over write the config.
I would like to pass a variable or append the timestamp so that the backup is archived versus overwritten on the FTP server.
I can't seem to find any information on how to pass a variable or include the timestamp in the file transfer.
11 Replies 11
Joe Clarke
This is not possible in ASA EEM.  The closest thing is the output file rotate capability.  Where you can rotate the output file can change with an incrementing number.  If you keep this on flash and copy the file to your FTP server, you could at least have a unique name.
So you are saying store the file locally first with the EEM and then copy it off to the ftp server?
Yes, using output file rotate.
ronshuster
Can you share that script pls?
I have not gotten the output file rotate function to work correctly. As soon as I do, I will post it here.
Here is what I have right now:
event manager applet Config_Backup
event timer absolute time 0:00:00
event none
action 1 cli command "enable"
action 2 cli command "copy /noconfirm running-config ftp://user:pass@x.x.x.x/firewallname.ftp.config"
action 3 cli command "exit"
output none
Thanks Jason, does this work on both x and non x series ASA's?
Any minimum requirements as far as IOS code?
I am not sure about non X series and I am on 9.2(3) for all my sites.
Jason, so every time I would "wr me" on the firewall the script will copy the config to my tftp server? Same concept as "archive"?  Or is there something else that would trigger the copy?  Thanks again.
what I did is to lisen to the syslog id 111005 (end configuration):
event syslog id 111005
this way, as soon as there is a config change the ASA copies the file to the SCP server.
I'm using this config for weekly backup:
event manager applet backup
 event none
 event timer watchdog time 604800
 action 0 cli command "backup /noconfirm location tftp://X.X.X.X/"
 output none
and output is hostname.backup.timestamp.tar.gz
Thank you very much, jaromir.grich.888 for this great answer!
