Cisco Bandwidth limit using policy and class map
salehahmedovic
Hello All,
i have one subnet /24 and wants a specific ip to consume BW 2M and the whole other IPS to consume 6M so i created access list and applied the below configuration but error "cannot attach queuing-based child policy to a non-queuing based class" has appeared and configuration can't be applied
Router version: Cisco 888EA-K9
Vesrion:
#show version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Mar-14 20:07 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
the below IPs are just for example
access-list 101 permit ip any 10.0.0.0 0.0.0.63
access-list 101 permit ip any 10.0.0.64 0.0.0.31
access-list 101 permit ip any 10.0.0.96 0.0.0.15
access-list 101 permit ip any 10.0.0.112 0.0.0.7
access-list 102 permit ip any 10.0.0.120 0.0.0.0 ## Server "2M"
access-list 101 permit ip any 10.0.0.121 0.0.0.0
access-list 101 permit ip any 10.0.0.122 0.0.0.0
access-list 101 permit ip any 10.0.0.123 0.0.0.0
access-list 101 permit ip any 10.0.0.124 0.0.0.3
access-list 101 permit ip any 10.0.0.128 0.0.0.127
(config)#policy-map physical
(config-pmap)#class class-default
(config-pmap-c)#service-policy subnets
Cannot attach queuing-based child policy to a non-queuing based class
#show running-config class-map subnet-a
Building configuration...
Current configuration : 63 bytes
class-map match-all subnet-a
match access-group 101
end
#show running-config class-map subnet-b
class-map match-all subnet-b
match access-group 102
end
#show running-config policy-map subnets
Current configuration : 109 bytes
policy-map subnets
class subnet-a
  bandwidth percent 75
 class subnet-b
  bandwidth percent 25
end
#show running-config policy-map physical
Current configuration : 113 bytes
policy-map physical
class class-default
  police 8000000 conform-action transmit  exceed-action drop
end
it is probably complaining that you police the parent class.
Try the below:
policy-map subnets
class subnet-a
priority 2048
class subnet-b
priority 6144
class class-default
fair-queue
policy-map physical
class class-default
shape average 8000000
