11-01-2018 11:53 AM
for some reason I cannot remore ssh to my C9400,
I tried to ssh directly and it works.
I going through a FW but the firewall is allowing the traffic,
I used the same cable to connect a different Switch and it works , so I know is not the FW.
I follow the steps in creating a domin name TEST.com
generated crypto key
I do not know what else I am missing
11-01-2018 01:17 PM
Do you get any response when attempting to SSH? i.e. connection refused? no response?
It works when you are local, but not when traversing firewall? I that correct?
11-01-2018 01:19 PM
