I have a UCS C24 M3S with IMC version 1.5(1f). I received an alarm from a Vulnerability detection service saying that this server is vulnerable to FREAK attack: https://geekflare.com/test-freak-attack-cve-2015-0204-and-fix/
Apparently the solution is to disable EXPORT cipher suites. Is there any common solution to do this? or the issue is becouse the OLD CIMC version i may have.
Thanks for the help
