Cisco Configuration Professional can not create community
mocah
Cisco Configuration Professional v1.1 does not start properly on computer with ms Vista Professional system. I have installed application according to CP manual. Problem is that when Cisco CP starts I can not open "Create community" or any other button except "provide feedback" and Help button. Would you happened to know what could be wrong?
Thank you and kind regards, M
6 Replies 6
vikram
Hi M,
Was your problem solved? if not please send email to ccp-feedback@cisco.com.
regards,
vikram
joseph.gervais
I get this on 3 different Windows XP machines also. Three different downloads also. Windows firewall has been told to leave it alone and leave Java alone. Running Java 1.6.0_04-b12.
Please send your logs to ccp-feedback@cisco.com
What logs? Java?
CCP Logs --
Start -- All Programs -- Cisco Configuration Professional -- Collect Data for Tech Support
Please send the file to ccp-feedback@cisco.com
Hi Joseph,
If you have Nod32 antivirus unchecked in Internet Explorer from "web access protection".
Kind regards,
Marko Strucelj
