Cisco erase nvram or erase startup-config doesn't work in GNS3
write_erase
According to this article, I can delete the current startup configuration files and return the router to its factory default settings with the `erase nvram:` and `reload` command.
https://www.oreilly.com/library/view/cisco-ios-cookbook/0596527225/ch01s06.html
R1#erase ?
/all Erase all files(in NVRAM)
/no-squeeze-reserve-space Do not reserve space for squeeze operation
flash: Filesystem to be erased
nvram: Filesystem to be erased
pram: Filesystem to be erased
slot0: Filesystem to be erased
startup-config Erase contents of configuration memory
R1#erase nvram: ?
<cr>
R1#erase nvram:
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
R1#
*Mar 1 00:07:24.891: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram
R1#
R1#reload
Proceed with reload? [confirm]
I also tried `erase startup-config` and `reload`
The problem is nothing happens after that.
Please check if your flash is alright
R1# dir flash:/
If it is prompted something like this:
%Error opening flash:/ (No device available)
Means that the flash memory is broken. In GNS3 i had an issue with a Dynamips Router that  had that problem, so i better used IOSv Routers.
Be grateful for the good times that make you happy and for the bad times that taugth you a lesson!
8 Replies 8
Leo Laohoo
No one uses this anymore.
"wr erase" is what everyone use "in the wild".
"wr erase" also doesn't work. Basically I'm getting similar output as "erase nvram" or "erase startup-config"
Nothing happens after "reload"
Wait ... Is this a "real" Cisco router/switch or is this a simulator?
This is 3725 in GNS3
R1#sh ver | i Cisco IOS
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
R1#
Simulators have different (very) behaviour.
The command "wr erase" may not work and the old (and Cisco accepted) command of "delete startup-config" may need to be used.
R1#wr erase
[OK]
R1#
R1#delete startup-config
Delete filename [startup-config]?
Delete flash:startup-config? [confirm]
%Error deleting flash:startup-config (No device available)
R1#
Martin L
what device and what IOS version ?
R1# dir flash:/
